Malevolence Model - What Kits Are Needed?
Re: Malevolence Model - What Kits Are Needed?
Postby Kubu1212 » Sun Aug 28, 2011 11:23 am
Hello all together,
sorry for grabbing this old post, but is someone able to send me the parts list too?
Thank you very much, would appreciate it.
Regards Kubu1212
Kubu1212
Postby Drock » Tue Aug 30, 2011 4:18 am
Kubu1212 wrote:Hello all together,
Regards Kubu1212
Sure thing. PM me your e-mail address and I can send it to you.
Drock
Postby Tauchloewe » Fri Oct 28, 2011 4:37 am
Hi togehter, i am from Germany / Hamburg and found this Thread while searching for this Model for my son. Could someone be so Kind and Post The Part List for me? Or send it via pm / Email?
Would be Great.
Thank you
Thomas
Tauchloewe
Postby darthius » Sun Feb 05, 2012 3:34 pm
Apologies for resurrecting this thread yet again but could someone kindly help me with the parts list please?
Back when the instructions came out I was mad enough to sit down and draw one by one all the bricks in the inventory and I posted this in Eurobricks. However since then I have lost the inventory and dismantled the ship I built.
Thank you very much in advance. :)
darthius
Postby darthius » Mon Feb 06, 2012 12:33 pm
Anyone would be kind enough to email me the instructions please?
Thank you in advance.
darthius
Postby darthius » Tue Feb 07, 2012 4:47 pm
posted by mistake
darthius
Postby fallenangel327 » Tue Feb 07, 2012 6:04 pm
Something wrong with it being public? ;)
Spoiler: show
Numb. Color BL Part # Description
2 Black 2877 Brick, Modified 1 x 2 with Grill
4 Black 52107 Brick, Modified 1 x 2 with Studs on 2 Sides
2 Black 3023 Plate 1 x 2
2 Black 2445 Plate 2 x 12
4 Black 3020 Plate 2 x 4
1 Black 3795 Plate 2 x 6
2 Black 3028 Plate 6 x 12
2 Black 4510 Plate, Modified 1 x 8 with Door Rail
1 Black 3708 Technic, Axle 12
2 Black 3705 Technic, Axle 4
2 Black 6541 Technic, Brick 1 x 1 with Hole
4 Black 2730 Technic, Brick 1 x 10 with Holes
2 Black 32000 Technic, Brick 1 x 2 with Holes
1 Black 48496 Technic, Pin Connector Toggle Joint Smooth Double with 2 Pins
1 Black 32054 Technic, Pin Long WITH Friction Ridges Lengthwise and Stop Bush
18 Black 4459 Technic, Pin WITH Friction Ridges Lengthwise
4 Black 3680 Turntable 2 x 2 Plate, Base
4 Black 30503 Wedge, Plate 4 x 4 Cut Corner
2 Blue 3004 Brick 1 x 2
2 Blue 3002 Brick 2 x 3
4 Blue 6134 Hinge Brick 2 x 2 Top Plate Thin
2 Blue 30363 Slope 18 4 x 2
6 Blue 3039 Slope 45 2 x 2
2 Blue 3660 Slope, Inverted 45 2 x 2
3 Blue 43093 Technic, Axle Pin WITH Friction Ridges Lengthwise
45 Blue 4274 Technic, Pin 1/2
2 Blue 6558 Technic, Pin Long WITH Friction Ridges Lengthwise
2 Blue 3738 Technic, Plate 2 x 8 with 7 Holes
2 Blue 6636 Tile 1 x 6
2 Blue 41770 Wedge, Plate 4 x 2 Left
2 Blue 41769 Wedge, Plate 4 x 2 Right
2 Dark Blue 3062b Brick, Round 1 x 1 Open Stud
2 Dark Blue 6233 Cone 3 x 3 x 2
5 Dark Blue 3710 Plate 1 x 4
6 Dark Blue 3794 Plate, Modified 1 x 2 with 1 Stud (Jumper)
8 Dark Blue 3298 Slope 33 3 x 2
4 Dark Blue 3069b Tile 1 x 2 with Groove
5 Dark Blue 3068b Tile 2 x 2 with Groove
2 Dark Blue 30382 Wedge 2 x 16 Triple
2 Dark Blue 41770 Wedge, Plate 4 x 2 Left
2 Dark Blue 41769 Wedge, Plate 4 x 2 Right
2 Dark Bluish Gray 2357 Brick 2 x 2 Corner
1 Dark Bluish Gray 4070a Brick, Modified 1 x 1 with Headlight and Slot
4 Dark Bluish Gray 3062b Brick, Round 1 x 1 Open Stud
2 Dark Bluish Gray 43898 Dish 3 x 3 Inverted
2 Dark Bluish Gray 3937 Hinge Brick 1 x 2 Base
8 Dark Bluish Gray 3023 Plate 1 x 2
2 Dark Bluish Gray 3623 Plate 1 x 3
7 Dark Bluish Gray 3710 Plate 1 x 4
3 Dark Bluish Gray 3460 Plate 1 x 8
3 Dark Bluish Gray 3832 Plate 2 x 10
4 Dark Bluish Gray 3022 Plate 2 x 2
7 Dark Bluish Gray 3021 Plate 2 x 3
8 Dark Bluish Gray 3020 Plate 2 x 4
2 Dark Bluish Gray 3795 Plate 2 x 6
2 Dark Bluish Gray 3034 Plate 2 x 8
1 Dark Bluish Gray 3031 Plate 4 x 4
2 Dark Bluish Gray 3032 Plate 4 x 6
1 Dark Bluish Gray 3035 Plate 4 x 8
1 Dark Bluish Gray 3033 Plate 6 x 10
8 Dark Bluish Gray 60478 Plate, Modified 1 x 2 with Handle on End - (closed ends)
4 Dark Bluish Gray 2444 Plate, Modified 2 x 2 with Hole
6 Dark Bluish Gray 4032 Plate, Round 2 x 2 with Axle Hole
8 Dark Bluish Gray 61409 Slope 18 2 x 1 x 2/3 with 4 Slots
2 Dark Bluish Gray 4286 Slope 33 3 x 1
4 Dark Bluish Gray 3040 Slope 45 2 x 1
6 Dark Bluish Gray 6587 Technic, Axle 3 with Stud
1 Dark Bluish Gray 6538c Technic, Axle Connector (Smooth with x hole + orientation)
6 Dark Bluish Gray 3895 Technic, Brick 1 x 12 with Holes
2 Dark Bluish Gray 32018 Technic, Brick 1 x 14 with Holes
2 Dark Bluish Gray 32000 Technic, Brick 1 x 2 with Holes
3 Dark Bluish Gray 3701 Technic, Brick 1 x 4 with Holes
4 Dark Bluish Gray 3894 Technic, Brick 1 x 6 with Holes
2 Dark Bluish Gray 3648 Technic, Gear 24 Tooth (New Style with Single Axle Hole)
4 Dark Bluish Gray 41677 Technic, Liftarm 1 x 2 Thin
1 Dark Bluish Gray 32002 Technic, Pin 3/4
2 Dark Bluish Gray 6636 Tile 1 x 6
2 Dark Bluish Gray 4162 Tile 1 x 8
15 Dark Bluish Gray 2555 Tile, Modified 1 x 1 with Clip
1 Dark Bluish Gray 43723 Wedge, Plate 3 x 2 Left
1 Dark Bluish Gray 43722 Wedge, Plate 3 x 2 Right
4 Dark Bluish Gray 2450 Wedge, Plate 3 x 3 Cut Corner
6 Dark Bluish Gray 48183 Wedge, Plate 3 x 4 with Stud Notches
6 Dark Bluish Gray 41770 Wedge, Plate 4 x 2 Left
6 Dark Bluish Gray 41769 Wedge, Plate 4 x 2 Right
3 Dark Bluish Gray 32059 Wedge, Plate 4 x 6 Cut Corners
5 Dark Bluish Gray 50305 Wedge, Plate 8 x 3 Left
5 Dark Bluish Gray 50304 Wedge, Plate 8 x 3 Right
2 Dark Bluish Gray 60208 Wheel 31mm D. x 15mm Technic
1 Dark Red 3001 Brick 2 x 4
1 Dark Red 3666 Plate 1 x 6
4 Dark Red 3794 Plate, Modified 1 x 2 with 1 Stud (Jumper)
4 Dark Red 2431 Tile 1 x 4
1 Dark Red 3068b Tile 2 x 2 with Groove
2 Dark Red 6180 Tile, Modified 4 x 6 with Studs on Edges
1 Light Bluish Gray 63965 Bar 6L with Stop Ring
4 Light Bluish Gray 44728 Bracket 1 x 2 - 2 x 2
2 Light Bluish Gray 3622 Brick 1 x 3
2 Light Bluish Gray 2877 Brick, Modified 1 x 2 with Grill
2 Light Bluish Gray 30414 Brick, Modified 1 x 4 with 4 Studs on One Side
2 Light Bluish Gray 2653 Brick, Modified 1 x 4 with Groove
6 Light Bluish Gray 47457 Brick, Modified 2 x 2 x 2/3 Two Studs, Curved Slope End
1 Light Bluish Gray 3062b Brick, Round 1 x 1 Open Stud
4 Light Bluish Gray 4740 Dish 2 x 2 Inverted
2 Light Bluish Gray 6134 Hinge Brick 2 x 2 Top Plate Thin
2 Light Bluish Gray 298c02 Lever Small Base with Black Lever
2 Light Bluish Gray 60849 Minifig, Utensil Hose Nozzle Elaborate
1 Light Bluish Gray 577 Minifig, Weapon Lightsaber Hilt Straight
18 Light Bluish Gray 3023 Plate 1 x 2
6 Light Bluish Gray 3623 Plate 1 x 3
1 Light Bluish Gray 3710 Plate 1 x 4
6 Light Bluish Gray 3666 Plate 1 x 6
2 Light Bluish Gray 3832 Plate 2 x 10
7 Light Bluish Gray 2445 Plate 2 x 12
11 Light Bluish Gray 3022 Plate 2 x 2
7 Light Bluish Gray 3021 Plate 2 x 3
3 Light Bluish Gray 3020 Plate 2 x 4
7 Light Bluish Gray 3795 Plate 2 x 6
10 Light Bluish Gray 3034 Plate 2 x 8
2 Light Bluish Gray 3031 Plate 4 x 4
2 Light Bluish Gray 3035 Plate 4 x 8
2 Light Bluish Gray 3036 Plate 6 x 8
2 Light Bluish Gray 6019 Plate, Modified 1 x 1 with Clip Horizontal
13 Light Bluish Gray 3794 Plate, Modified 1 x 2 with 1 Stud (Jumper)
2 Light Bluish Gray 63868 Plate, Modified 1 x 2 with Clip Horizontal on End
6 Light Bluish Gray 60470 Plate, Modified 1 x 2 with Clips Horizontal
7 Light Bluish Gray 32028 Plate, Modified 1 x 2 with Door Rail
1 Light Bluish Gray 48336 Plate, Modified 1 x 2 with Handle on Side - Type 2 (closed ends)
2 Light Bluish Gray 4510 Plate, Modified 1 x 8 with Door Rail
1 Light Bluish Gray 41862 Plate, Modified 2 x 2 with Grills
2 Light Bluish Gray 3176 Plate, Modified 3 x 2 with Hole
14 Light Bluish Gray 4073 Plate, Round 1 x 1 May have added an extra one
7 Light Bluish Gray 2654 Plate, Round 2 x 2 with Rounded Bottom (Boat Stud)
2 Light Bluish Gray 50746 Slope 30 1 x 1 x 2/3
2 Light Bluish Gray 3298 Slope 33 3 x 2
3 Light Bluish Gray 3040 Slope 45 2 x 1
3 Light Bluish Gray 3039 Slope 45 2 x 2
8 Light Bluish Gray 61068 Slope, Curved 2 x 4 x 2/3 No Studs
8 Light Bluish Gray 61678 Slope, Curved 4 x 1 No Studs
1 Light Bluish Gray 3040pb10 Slope, Decorated 45 2 x 1 with Green and Red Buttons and Keypad Pattern
2 Light Bluish Gray 4287 Slope, Inverted 33 3 x 1
1 Light Bluish Gray 3665 Slope, Inverted 45 2 x 1
2 Light Bluish Gray 3713 Technic Bush
6 Light Bluish Gray 4265c Technic Bush 1/2 Smooth
4 Light Bluish Gray 32039 Technic, Axle Connector with Axle Hole
1 Light Bluish Gray 6541 Technic, Brick 1 x 1 with Hole
2 Light Bluish Gray 3700 Technic, Brick 1 x 2 with Hole
1 Light Bluish Gray 3894 Technic, Brick 1 x 6 with Holes
4 Light Bluish Gray 3743 Technic, Gear Rack 1 x 4
2 Light Bluish Gray 60483 Technic, Liftarm 1 x 2 Thick with Pin Hole and Axle Hole
1 Light Bluish Gray 32523 Technic, Liftarm 1 x 3 Thick
2 Light Bluish Gray 32526 Technic, Liftarm 3 x 5 L-Shape Thick
4 Light Bluish Gray 61184 Technic, Pin 1/2 with 2L Bar Extension
8 Light Bluish Gray 75535b Technic, Pin Connector Round with Slot
2 Light Bluish Gray 3069b Tile 1 x 2 with Groove
7 Light Bluish Gray 6636 Tile 1 x 6
1 Light Bluish Gray 4162 Tile 1 x 8
3 Light Bluish Gray 3068b Tile 2 x 2 with Groove
8 Light Bluish Gray 2412b Tile, Modified 1 x 2 Grill with Bottom Groove / Lip
2 Light Bluish Gray 6180 Tile, Modified 4 x 6 with Studs on Edges
2 Light Bluish Gray 4150px19 Tile, Round 2 x 2 with SW Radial Machinery Pattern
2 Light Bluish Gray 50955 Wedge 10 x 3 Left
2 Light Bluish Gray 50956 Wedge 10 x 3 Right
3 Light Bluish Gray 43723 Wedge, Plate 3 x 2 Left
3 Light Bluish Gray 43722 Wedge, Plate 3 x 2 Right
2 Light Bluish Gray 2450 Wedge, Plate 3 x 3 Cut Corner
1 Light Bluish Gray 48183 Wedge, Plate 3 x 4 with Stud Notches
3 Light Bluish Gray 41770 Wedge, Plate 4 x 2 Left
3 Light Bluish Gray 41769 Wedge, Plate 4 x 2 Right
2 Light Bluish Gray 30503 Wedge, Plate 4 x 4 Cut Corner
5 Light Bluish Gray 54384 Wedge, Plate 6 x 3 Left
5 Light Bluish Gray 54383 Wedge, Plate 6 x 3 Right
3 Light Bluish Gray 50305 Wedge, Plate 8 x 3 Left
3 Light Bluish Gray 50304 Wedge, Plate 8 x 3 Right
2 Light Bluish Gray 42610 Wheel 11 x 8 mm with Center Groove
2 Light Bluish Gray 55982 Wheel 30.4 x 14 with Axle Hole, Fake Bolts and Shallow Spokes
2 Light Bluish Gray 60208 Wheel 31mm D. x 15mm Technic
1 Light Bluish Gray x224 Windscreen 8 x 6 x 2 Curved
1 N/A 8016stk01 Sticker for Set 8016 - (85153/4542684)
1 N/A 8017stk01 Sticker for Set 8017 - (85465/4543749)
1 N/A 8036stk01 Sticker for Set 8036 - (86451/4550366)
2 Red 32062 Technic, Axle 2 Notched
1 Tan 6232 Brick, Modified 2 x 2 with Pin and Axle Hole
2 Tan 2654 Plate, Round 2 x 2 with Rounded Bottom (Boat Stud)
2 Tan 32198 Technic, Gear 20 Tooth Bevel
11 Trans-Light Blue 4073 Plate, Round 1 x 1
1 Trans-Yellow 4073 Plate, Round 1 x 1
4 White 3937 Hinge Brick 1 x 2 Base
2 White 3024 Plate 1 x 1
5 White 3023 Plate 1 x 2
2 White 3623 Plate 1 x 3
2 White 3022 Plate 2 x 2
1 White 3020 Plate 2 x 4
2 White 3034 Plate 2 x 8
4 White 60478 Plate, Modified 1 x 2 with Handle on End - (closed ends)
2 White 32064 Technic, Brick 1 x 2 with Axle hole
3 Yellow 3001 Brick 2 x 4
1 Yellow 6232 Brick, Modified 2 x 2 with Pin and Axle Hole
8 Yellow 3023 Plate 1 x 2
3 Yellow 3022 Plate 2 x 2
3 Yellow 3020 Plate 2 x 4
2 Yellow 3795 Plate 2 x 6
1 Yellow 64799 Plate, Modified 4 x 4 with 2 x 2 Cutout
2 Yellow 2431 Tile 1 x 4
1 Yellow 6636 Tile 1 x 6
2 Yellow 51739 Wedge, Plate 2 x 4
1 Yellow 41770 Wedge, Plate 4 x 2 Left
1 Yellow 41769 Wedge, Plate 4 x 2 Right
1 Yellow 54384 Wedge, Plate 6 x 3 Left
1 Yellow 54383 Wedge, Plate 6 x 3 Right
752
Credit goes to Sir_Basil_Ashton of Eurobricks, who received it from someone else a while back and was kind enough to post it.
Postby darthius » Wed Feb 08, 2012 2:15 pm
Fallenangel, thank you very much indeed. :)
darthius
Postby Draykov » Thu Feb 09, 2012 10:20 am
darthius wrote:Fallenangel, thank you very much indeed. :)
In the future, I'd encourage you to make use of a PM rather than sharing your E-mail address with the world.
FBTB Code of Conduct wrote:2. Keep all private information private.
Members are never to post personal or confidential information about any other person, and are encouraged to exercise good judgment about revealing their own.
Postby darthius » Thu Feb 09, 2012 10:31 am
Thank you for the advice.
That is an email that is not associated with any accounts and I just keep it for receiving this sort of info only. That account doesn't last longer than 3 months either so I judged it would be safe to post it.
darthius
Users browsing this forum: No registered users and 10 guests
