So, you wanna to build a podracer? [Building Tips Thread]
Re: So, you wanna to build a podracer? [Building Tips Thread]
Postby StormieMan » Sun Mar 08, 2009 9:20 pm
Could we use stuff like technic spears on our podracer? Or could we use them for a decoration, instead of a weapon?
StormieMan
Postby Solo » Mon Mar 09, 2009 9:25 am
I've never heard the term "technic sprears" but as long as it's an official part you can use it on your entry.
Postby SuperDave » Wed Mar 11, 2009 7:33 am
StormieMan wrote:technic spears?
These things?
SuperDave
Postby StormieMan » Wed Mar 11, 2009 4:03 pm
yeah...
StormieMan
Postby Jon Vanneste » Thu Mar 12, 2009 10:57 pm
Can I have a co-pilot?
Imperial troops have entered the forums! Imperial troops have entered the f-KSSHHHH.
Jon Vanneste
Postby Solo » Thu Mar 12, 2009 10:59 pm
Sure, why not... :D
Postby Jargon » Fri Mar 13, 2009 10:07 am
Can my podracer be fully sentient/self-aware??? :D
    - Aaron
mumbles . . . not a half-bad idea . . .
Jargon
Postby Solo » Fri Mar 13, 2009 10:15 am
Nope, needs a pilot. But it can have a droid pilot.
Postby FizzyPoppers » Fri Mar 13, 2009 11:58 pm
Could we add a built setting to our pod-racer pictures? Also, will the support for your pod have to be made of lego?
http://www.brickshelf.com/gallery/Arthi ... /rr6_7.jpg Like this. The support isn't lego, it's just a transparent stand. Is that legal?
Image YOU MUST CHOOSE... Image
FizzyPoppers
Postby Solo » Sat Mar 14, 2009 12:16 am
It's just a stand, it doesn't need to be brick built. If at all possible it should be photoshopped out to make your entry look better. If you want to build some scenery like some brick landscaping, you're welcome to. Just keep in mind the contest is about the podracers, not the background.
Postby starstreak » Mon Mar 16, 2009 10:55 pm
Unless I missed it, only the podracer is being judged right? I mean, all because someone is good at adding a background via photoshop or has tons of bricks to build a landscape, would they get more points?
starstreak
Postby Solo » Mon Mar 16, 2009 11:58 pm
That is the intent, yes, but presentation is still important. You can have an identical creation and shoot one with a cameraphone and the other with a decent lighting setup, and the second is going to look better. Same for shopping out the stand vs not, or adding scenery (brick built or digital). The contest is only about the podracers - it's up to each member to build theirs as best they can and present it as best they can.
A hint on the judging - it's going to be completely up to the forum members through a series of polls. So there's no way to account for everyones taste or bias, but you don't have to worry about points for specific things included or excluded.
Postby Flynn » Tue Mar 17, 2009 6:23 pm
Quick question, are we allowed to cut the cables down to the appropriate size, or does that fall under the "no modifying parts" rule?
Postby Solo » Tue Mar 17, 2009 8:10 pm
Flex tube, as far as I'm concerned, is the only element where cutting is acceptable - since a number of sets required you to do this in the official instructions.
Postby FizzyPoppers » Thu Mar 19, 2009 11:51 am
so four engines are illegal, right? And also, contest entrys should use fire for the power couplings to give it a nice effect.
FizzyPoppers
Postby Solo » Thu Mar 19, 2009 12:16 pm
It's right there in the first post: They're not banned from the competition - just make sure it doesn't suck, because then you have twice the suck you would have had with a regular pod. ;)
Postby bigospedros » Thu Mar 19, 2009 5:48 pm
Question : I already posted an entry, but I've re-worked it. Can I withdraw my first attempt and re-enter with Version 2 ?
bigospedros
[CONTEST] 2009 Podracer Challenge!
Postby Joedward » Sat Mar 21, 2009 8:15 am
On the other hand;
Power couplings/energy binders requirement:
That's right, these are REQUIRED and should be the only thing connecting your two engine pods together. How they look is up to you, but try and stick to these suggestions:
- it should be made from transparent elements to properly simulate the look
There are many ways to accomplish this and you still have room to play, so try out everything you can think of. ...
Does that mean they have to be made of transparent elements? Or is it just a very strong recomendation?
Re: [CONTEST] 2009 Podracer Challenge!
Postby Gold_2 » Sat Mar 21, 2009 12:05 pm
Glad 4-engine designs aren't illegal. Ben Quadinaros rocked a 4-engine pod. Well, sorta. ;)
Gold_2
Postby Kyle » Sat Mar 21, 2009 1:43 pm
Gold_2 wrote:Glad 4-engine designs aren't illegal. Ben Quadinaros rocked a 4-engine pod. Well, sorta. ;)
I think it'd be more accurate to say Ben Quadinaros got rocked by a 4-engine pod. ;)
Kyle
