Quit Wasting Money On Brasso
There's more to LEGO than building, here you can take the hobby in a much different direction.
Moderator: Kaminoan
Re: Quit Wasting Money On Brasso
Postby Thunder-blade » Thu Feb 12, 2009 9:18 am
Also, will any eraser work? Or just the ones that are the back of pencils?
Thunder-blade
Postby Monkfish » Thu Feb 12, 2009 9:21 am
It takes me a few minutes for a torso, and for the example picture it took about a minute. I use one of these:http://www.stampeaz.com/images/staedtler_eraser.jpg
Monkfish
Postby uubergeek » Thu Feb 12, 2009 9:34 am
Andi wrote:Can we speak about time?
How long do you have to erase the print before it is gone? A couple of seconds? Or several minutes? Or even longer than 10 minutes?
With brasso I need at least 3 minutes continuous rubbing before the print is as good as vanished.
3minutes?!?! i brasso a full torso with multiple colors in less than 10s use a little elbow grease :) the trick i use is to get a cloth with the brasso on it, and put it on a hard surface, then rub the part on the cloth, rather than rub the cloth on the part ... i actually use a cloth stapled down to a wooden block so i can take it wherever i want
Chris C. :::: My Flickr :::: My Site
uubergeek
Postby Kaminoan » Thu Feb 12, 2009 9:39 am
Your doing it wrong then Andi.
Take a cloth (low lent - I like car wash yellow cloths) Add brasso
Lay the cloth on a flat surface
take the torso in your hand
rub on the cloth (you are moving the torso, not the cloth)
You should have the torso clean in about 20-30 seconds (The one exception to this time frame is white printed LEGO designs, these are printed in multiple coats and thus a bit thicker and take longer to remove).
- K
Kaminoan
Why Live in the Box? Customize Your World!!!
Fine Clonier
FineClonier@gmail.com
Kaminoan
Postby Iare Tosevite » Thu Feb 12, 2009 7:47 pm
Can those 16000 grit sandpaper used to polish clear plastics? I have some parts i would love to see shiny again.
Where, where, where is correct way out?
Iare Tosevite
Postby JPCJedi » Thu Feb 12, 2009 10:48 pm
With Brasso I need at least 3 minutes continuous rubbing before the print is as good as vanished.
I have used both methods, and the eraser is slower. I've made the same mistake of moving the cloth instead of running the torso across a stationary Brasso'd cloth like Kam said, so Brasso takes me a few minutes.
Firm erasers work better, and even those take five minutes to completely remove a torso print.
Bricklink|Flickr
When the Lord spits in your face, he’s trying to cure you of something.--John 9:1-41
JPCJedi
Postby Solo » Thu Feb 12, 2009 10:56 pm
It's still quicker and easier than going out and buying a bottle of Brasso if you're doing some minor detail stuff. ;)
Postby Thunder-blade » Thu Feb 12, 2009 11:29 pm
Kaminoan wrote:Your doing it wrong then Andi.
- K
So that's why it takes so long!
Thunder-blade
Postby Andi » Fri Feb 13, 2009 3:05 am
well, thanks Kam. Have to try it this way.
Postby EwokWarrior » Sat Feb 14, 2009 10:29 am
Thanks for the tip. I've heard it before, but I never tried it. I used it to remove the stubble on an Indy head. I'll post a pic in a while.
Who am I? I am the galaxy's top Ewok warrior. That is all anyone needs to know.
Brickshelf: http://www.brickshelf.com/cgi-bin/gallery.cgi?m=EwokWarrior
EwokWarrior
Postby Kaminoan » Tue Feb 17, 2009 8:38 am
Iare Tosevite, yes yes they can. They can bring the luster back to any part. I am truly amazed by then and have even found that they make sanding swabs now. I have two different sized sets on order. Really amazing stuff this sand paper.
Kaminoan
Kaminoan
Fine Clonier
Kaminoan
Postby Ty55 » Wed Apr 08, 2009 6:06 am
Could anyone possibly help me with a question I have regarding this method? Is it possible to remove the printing on this part with Brasso? possibly super fine grit sandpaper?
What's your recommendation for ease?
http://www.bricklink.com/catalogItem.asp?P=30117pb01
I know it's not really mini-fig related, but I figured you custom guys might be able to help. Thank you!
Ty55
Postby captain brick » Wed Apr 08, 2009 2:32 pm
I use scissors to scrape off the marks, this method didn't work for me.
captain brick
Postby Turkguy19 » Wed Apr 08, 2009 9:18 pm
Ty55 wrote:Could anyone possibly help me with a question I have regarding this method? Is it possible to remove the printing on this part with Brasso? possibly super fine grit sandpaper?
I used brasso to remove the print from one of those before....and if I remember correctly, it was a pain. But, it is possible to remove it with brasso.
Turkguy19
Postby Chief » Wed Apr 08, 2009 11:57 pm
Ugh, I did the same to this for this:
I swore I'd never do it again (and to this day I've stuck to that vow!)
Nice tip on the erasers. Sounds useful for small projects, at least.
Chief
Postby Ty55 » Thu Apr 09, 2009 8:03 am
Well I've heard of another method of removing print, I found it here:
http://www.lugnet.com/~330/FAQ/Build/remove
Do you think If I sanded it down and then used that polish to restore some of the luster it would be faster?
Ty55
Return to Custom Minifigs
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 3 guests
